Ребята, помогите!
Суть в следующем. Перед фильтром FF 120-77 (загрузка МЖФ) дозируется ПЕРХЛОРАТ НАТРИЯ марки А как окислитель растворенного железа. Дак вот, сколько его надо дозировать на 1 м3 проходящей воды?
И второй вопрос. После фильтра FF 120-77 дозируется АМИНАТ КО-2. То же самое, сколько его нужно дозировать?
Прошу ответить )))
Сколько нужно реагентов?
replicae74006
Replica Prada Handbags Tend to be Design along with Standing
hermes replica watches, celine replica handbags, replica rado As a famous label of merchandise mix, Replica Prada Handbags Firm also producers a wide range of Prada versions that contains sun shades, tools, fragrances as well as a plenty of garments. Ascribe to the telltale updates, e-commerce regarding high quality Prada reproductions has shared great popularity and also enchantment from all kinds of Prada loves all around. And as a result of state-of-art technological innovation and modern approach straight into modern society, replicated Prada Handbags get been able to improve their design and quality, increasing rejuvenating variations and maintaining the people's curiosity about Prada living. Transporting things associated with Prada things could enhance their existence simply because they thinks satisfied with possessing the brand and displaying this in front of their close friends means they are pleased. Those who find themselves crazy in love with Prada Handbags can now enjoy the increase associated with Prada Handbags identical.
http://www.designerscarves2u.com/design ... 20664.html" onclick="window.open(this.href);return false;
http://www.watchrex.com/luxury-louis-vu ... 45116.html" onclick="window.open(this.href);return false;
http://www.tourva.com/watches/replica-o ... n-get.html" onclick="window.open(this.href);return false;
http://www.sodeliciouses.com/handbags/m ... dbags.html" onclick="window.open(this.href);return false;
http://www.newebags.com/designer-watche ... nacle.html" onclick="window.open(this.href);return false;
molotoboec
- sibecco
Re: Сколько нужно реагентов?
Дозируй дешевый гипохлорит натрия (NaOCl) фасовочной концентрацией 35%. На 1 м.куб воды при содержании железа от 1 до 3 мг/л - 100 мл. При содержании железа от 3 до 10 мг/л - 200 мл.
Дешево, везде есть и вдобавок обеззараживает конкретно.
Водоподготовка, водоочистка
Евгений Буш
Инструкция
дозирования реагента АМИНАТ марки КО-2
(в импульсном режиме)
Содержание
1. Описание и условия применения реагента.
2. Определение рабочих настроек комплекса дозирования.
3. Приготовление рабочего раствора.
4. Техника безопасности и условия хранения реагента
Приложение
1. ОПИСАНИЕ И УСЛОВИЯ ПРИМЕНЕНИЯ РЕАГЕНТА.
Реагент АМИНАТТМ КО-2 предназначен для связывания кислорода при эксплуатации закрытых систем теплоснабжения и паровых котлах низкого и среднего давления (до 4МПа). Реагент АМИНАТТМ КО-2 (ТУ 2149-098-17965829-03) представляет собой катализированный раствор метабисульфита натрия с концентрацией по активному веществу 35% и характеризуется низким значением рН (3,5-5,0).
При добавлении метабисульфита в воду в результате гидролиза происходит образование сульфита натрия согласно следующим реакциям:
Na2S2O3 + Н2O = 2NaНSO3
NaНSO3+ NaOН = Na2S O3 + Н2O
Как видно из приведенных реакций образование сульфита натрия будет зависеть от концентрации гидроксил-ионов, которые в природных водах образуются за счет гидролиза бикарбонат-ионов (щелочности воды). При этом происходит понижение рН обработанной воды, поэтому чем ниже щелочность (буферность) обрабатываемой воды, тем заметнее влияние дозирования АМИНАТа КО-2 на значение рН. Для обеспечения условий процесса химического обескислороживания в воде с низкой щелочностью (менее 2 мг-экв/л) необходимо дополнительно дозировать щелочные реагенты (АМИНАТТМ КО-5).
Взаимодействие АМИНАТТМ КО-2 с кислородом происходит в результате следующей реакции:
О2 + 2Na2SO3 = 2Na2SO4
Согласно стехиометрии доза реагента по активному веществу рассчитывается по формуле:
DSО32- = 8 • O2 + i, [мг/ дм3]
где: O2 – содержание кислорода в питательной воде до обработки, мг/ дм3;
i - избыток сульфит -ионов в питательной воде.
Рекомендуемый избыток сульфит-ионов в сетевой воде систем теплоснабжения при низких концентрациях кислорода и температурах выше 60 оС составляет 1-3 мг/ дм3.
Доза реагента напрямую зависит от концентрации кислорода, причём скорость и глубина взаимодействия возрастают с увеличением избытка реагента. Чем выше температура обрабатываемой воды, тем быстрее происходит химическое связывание кислорода. Оптимальная температура химического обескислороживания находится в пределах 60-70оС, при этом время взаимодействия составляет 10-20 секунд.
Для эффективного использования данного реагента необходимо учитывать следующие особенности и ограничения:
- при выборе точки ввода реагента необходимо обеспечить отсутствие взаимодействия обработанной воды с кислородом воздуха, т. е. дозирование непосредственно в линию обрабатываемой воды или в герметичные накопительные баки;
- необходимым условием является использование специальной ёмкости рабочего раствора с крышкой, препятстующей доступу кислорода из воздуха;
- для водогрейного оборудования обязательна предварительная оценка возможности дозирования АМИНАТТМа КО-2 в воду, не прошедшую умягчение на натрий-катионитных фильтрах. Ограничение в применении реагента связано с опасностью образования сульфатных отложений для вод с высоким содержанием сульфит-ионов и кислорода в исходной воде.
Физические свойства реагента АМИНАТ КО-2
- содержание основного вещества - 35 %
- рН - 3.5 – 5.0
- внешний вид - жидкость розового цвета
- плотность - 1,25 г/см3 (кг/дм3)
2. ОПРЕДЕЛЕНИЕ РАБОЧИХ НАСТРОЕК КОМПЛЕКСА ДОЗИРОВАНИЯ.
Для обеспечения требуемых доз реагента АМИНАТТМа КО-2 в подпиточной и сетевой воде рекомендуется использовать комплексы пропорционального дозирования.
В состав комплекса пропорционального дозирования входят: насос-дозатор, импульсный водосчётчик и ёмкость рабочего раствора. По сигналу водосчетчика насос дозирует реагент в импульсном режиме. Можно установить два различных вида пропорциональной зависимости от внешнего сигнала:
а) Режим 1: n – после каждого внешнего импульса от счётчика воды, присоединённого к насосу-дозатору, насос произведёт «n» ходов (впрысков) реагента.
б) Режим n:1 – после каждых «n» внешних импульсов от счётчика воды, присоединённому к насосу, насос произведёт 1 ход (впрыск) реагента.
Рабочие настройки насоса-дозатора определяются по объемной подаче каждого из реагентов из условия равенства:
D реаг.. V имп.расх. = Сраб.р. . Vреаг.раб.р.
где D реаг – расчетная доза реагента по активному, мг/л;
V имп.расх – расход воды на 1 импульс импульсного расходомера, л;
Сраб.р. - концентрация реагента в рабочем растворе, г /л ;
Vреаг.раб.р. - объем впрыска насоса-дозатора на 1 импульс воды, мл.
Концентрация рабочего раствора рассчитывается согласно разбавлению:
Сраб.р. = С (КОНЦ.Р,) / Кразб.
Коэффициент разбавления рассчитывается по формуле:
Кразб.= Q раб.емк. /q реаг. = Q раб.емк. /V реаг.. ρ
где: Q раб.емк. – количество приготавливаемого рабочего раствора, кг;
q реаг. - количество товарного реагента, кг;
V реаг - объем товарного реагента, дм3;
ρ - плотность товарного реагента, кг/дм3.
Рассчитанное необходимое значение объема впрыска насоса-дозатора сопоставляется с максимальным объемом одного впрыска насоса-дозатора Vmax, который определяется на основании паспортных данных:
Vmax = ПН-Д / N х 60 мл/ход
где: ПН-Д – производительность насоса-дозатора (паспортные данные), мл/ч;
N - максимальное число ходов насоса-дозатора в минуту (паспортные данные), ход/мин.
а) Если расчётное значение необходимого объёма впрыска рабочего раствора больше максимального объёма одного впрыска насоса-дозатора, то насос-дозатор следует настроить на работу в режиме «1: n» .
Для расчёта требуемого значения «n» используется формула:
n = Vреаг.раб.р. / Vmax
где: n – необходимое число ходов насоса-дозатора на 1 импульс водосчётчика.
Если n получилось целое число, то объём хода насоса-дозатора устанавливается 100%.
Если n получилось не целое число, то его надо округлить до целого числа и с в случае необходимости откорректировать разбавление реагента.
Если в число регулируемых настроек данной модели насоса-дозатора входит объём хода, то более точную дозировку можно установить из соотношения:
VХ. Н-Д = Vреаг.раб.р. х 100/n . Vmax, %
б) Если расчётное значение необходимого объёма впрыска рабочего раствора меньше максимального объёма одного впрыска насоса-дозатора, то насос-дозатор следует настроить на работу в режиме «n:1»
Для расчёта требуемого значения n используется формула:
n = Vmax / Vреаг.раб.р.
Если n получилось целое число, то объем, хода насоса-дозатора устанавливается 100%.
Если n получилось не целое число, то его надо округлить до целого и более точную настройку дозирования установить, вычислив объём хода насоса-дозатора из соотношения:
VХ. Н-Д = Vреаг.раб.р. х n х100 / Vmax, %
Приведённые выше расчёты по установки расхода насоса-дозатора могут быть использованы как в период пуско-наладочных работ, так и для корректировки дозы реагента в случаях:
- изменения качества обрабатываемой воды;
- изменения источника водоснабжения;
- изменения продувки парового котла;
- перехода на реагент с другой концентрацией основного вещества.
Дозирование реагента АМИНАТТМа КО-2 должно обеспечивать содержание остаточного растворенного кислорода в подпиточной воде водогрейных котлов и питательной воде паровых котлов от 20 до50 мкг/л, в зависимости от типа оборудования. Превышение остаточной концентрации кислорода в обрабатываемой воде выше нормируемых значений может быть связано с недостаточным временем химического взаимодействия, либо с недостаточной дозой реагента.
Контроль эффективности обескислороживания с использованием АМИНАТа КО-2 осуществляется по величине избытка сульфит-ионов, который должен составлять:
- в сетевой воде водогрейного оборудования – на уровне 2 -4 мг/л;
- в котловой воде - 20 – 40 мг/л.
Если в установившемся режиме дозирования сульфит-ионы не определяются в воде, необходимо корректировать дозу и расход реагента даже при отсутствии кислорода в сетевой воде.
Методика определения сульфит-ионов в воде приведена в Приложении настоящей Инструкции.
3. ПРИГОТОВЛЕНИЕ РАБОЧЕГО РАСТВОРА.
Для интенсификации процесса обескислороживания и более точного дозирования реагента АМИНАТТМа КО-2 товарный реагент дозируется в разбавленном виде из специальной рабочей ёмкости.
Для приготовления рабочего раствора используется умягченная вода. Коэффициент разбавления рассчитывается по формуле:
На момент приготовления рабочего раствора реагента насос-дозатор необходимо отключить.
Первоначально в рабочую ёмкость заливается около 10-20 литров умягчённой воды. Затем заливается рассчитанный объём товарного реагента АМИНАТ КО-2 и доливаем умягченную воду до максимальной отметки рабочей ёмкости. После этого плотно закрывается крышка рабочую ёмкость и включается насос-дозатор.
4. ТЕХНИКА БЕЗОПАСНОСТИ И УСЛОВИЯ ХРАНЕНИЯ РЕАГЕНТА.
Реагент АМИНАТТМ КО-2 вещество умеренно опасное, нетоксичное, относится к 4 классу опасности по ГОСТ 12.1.007-76. Персонал, принимающий участие в обслуживании комплекса дозирования (приготовлении рабочего раствора), должен пройти инструктаж по ТБ в связи с работой с химическими реагентами и с записью в журнале инструктажа.
Персонал, участвующий в работе по приготовлению рабочего раствора реагентов, должен обеспечиваться средствами индивидуальной защиты: защитными очками, резиновыми перчатками и респираторами.
При несоблюдении мер предосторожности и попадании реагента в глаза или на кожу необходимо смыть его большим количеством проточной воды. При необходимости обратиться к врачу. Для оказания первой помощи рабочее помещение должно быть обеспечено аптечкой.
Реагент хранят в крытых вентилируемых складских помещения. При размораживании и перемешивании восстанавливает свои свойства. Гарантийный срок хранения в ненарушенной упаковке – 12 месяцев со дня изготовления.
Добавлено спустя 4 минуты 9 секунд:
а мне интересно
1. как приклеплять файл к сообщению
2. инструкция по дозированию Экотрит 27 коррекция шелочности
Содержание
Приложение
- рН - 3.5 – 5.0
а мне интересно
